Can anyone help me identify following IC?
1\$\begingroup\$ There are SMD code search sites suggesting a TLVH431BIDBZT voltage regulator. \$\endgroup\$– greybeardCommented Jun 20, 2023 at 8:30
3\$\begingroup\$ What are the dimensions of the IC? \$\endgroup\$– uriyabscCommented Jun 20, 2023 at 8:35
2\$\begingroup\$ If dimensions match, perhaps Toshiba PNP transistor RN2131F? datasheet Can you show some more of the board and the surrounding parts, that really helps give context \$\endgroup\$– jonathanjoCommented Jun 20, 2023 at 8:36
1\$\begingroup\$ Most definitely a wider angle picture is needed - this part can literally be anything, but with some context it should be possible to narrow down the possibilities. \$\endgroup\$– Vladimir CraveroCommented Jun 20, 2023 at 8:41
Add a comment
1 Answer
It's a Texas Instruments TLVH431BIDBZT voltage reference (as commented by greybeard).
(Source: lcsc.com)
- The "D" designator and the pinout matches:
\$\begingroup\$ @HNLinh If you think the answer is correct, please accept it with the checkmark symbol. \$\endgroup\$– nanash1Commented Jun 21, 2023 at 10:40
