So, I'm trying to build a Van de Graaff generator from household items, but after a lot of tries, I'm still unable to get it working and was hoping someone here could help.
The problem is that no matter how long I leave it to run, there's just no charges accumulating on the dome at all.
Here are my observations and some things I measured:
  • the belt is spinning and there is enough friction between the belt and the rollers
  • the bottom comb is connected to the ground (measured with my multimeter)
  • the top comb is connected to the inner side of the dome (measured with my multimeter)
  • the belt is not touching the combs
  • voltage and current (when the machine's running) between the dome and ground are constantly 0
Now for the materials I used:
  • I built the main support structure out of wood
  • the combs are just spread out copper wire
  • the bottom roller is made out of silicon tube
  • the top roller is made out of wool wrapped around a piece of pen
  • the belt is a piece of electric tape with the sticky side facing outwards
  • the dome is made out of 2 metal hemispheres held together with some electric tape
Here are some pictures of the machine: The whole machine Bottom comb Top roller and comb The underside Metal hemisphere with the top comb
I've searched the internet and found some forum posts as well as sites for debugging Van de Graaff generators and followed their steps for troubleshooting, but with no success.
I should also mention that I've already changed the material of the bottom roller and the belt (the roller used to be polypropylene and the belt used to be some elastic cloth that I sawed into a belt) and I also made sure that the rollers are leveled and that the belt is centered.
(Also, I know that connecting things with hot glue isn't a great idea, but it's the best thing I had)
    \$\begingroup\$ I can't speak to how well electrical tape works as a belt, but I can say that wood is not great as a support structure. Electrical tape as insulation won't work well for static electricity and don't bother trying to measure voltage with a multimeter (make your own electroscope with a glass jar and aluminum foil). \$\endgroup\$
    – vir
    Commented Jul 28, 2023 at 21:45
  • \$\begingroup\$ Wood is just straight up a conductor at the high voltages and low currents that a Van de Graaff generator produces. I had the same problem with a Wimshurst machine. Even at the lower voltage that a Wimshurst machine produces, the charge leaked away through the wooden supports faster than the machine could generate it. \$\endgroup\$
    – JRE
    Commented Aug 4, 2023 at 13:25
You design is innovative and creative, but could be improved.
  1. As mentioned, wood absorbs water and, particularly in humid conditions, is not a good enough insulator. Plastic drain pipe, 50 mm or larger diameter, is not expensive and works better.
  2. The combs must be within a mm of the belt to be effective, and slightly to opposite sides rather than directly atop or bottom.
  3. There should not be friction at top and bottom rollers.
  4. Rubber bands make effective belts, not vinyl tape. One can cut them from bicycle inner tubes, for long columns, or just use large bands from a stationery store. Thin bands work better because they travel over the rollers with less friction and internal heating.
Also, in humid weather, most generators won't start without a DC booster.
Trivia: I once met Robert Van de Graaff at Ion Physics Corp., which made powerful electrostatic generators running in SF6.
  • \$\begingroup\$ Thank you for the answer, I will definitely try everything you mentioned. I have a question about 3rd point though, wouldn't no friction between the rollers and the belt mean that the belt wouldn't spin? What I imagine would happen if there'd be no friction is that the bottom roller (the one connected to the motor) would spin while the belt stays in place? Could be that my logic is wrong or that I don't understand something correctly \$\endgroup\$ Commented Jul 29, 2023 at 9:30
  • \$\begingroup\$ An elastic band will provide tension and not slip, if the bearings are good. If that is nylon or Delrin tubing, or perhaps polyethylene, there should be ample force on the belt. However, it is not friction that creates the charge, but rather the triboelectric effect: en.wikipedia.org//wiki/Van_de_Graaff_generator \$\endgroup\$ Commented Jul 30, 2023 at 2:10
  • \$\begingroup\$ Interesting, I would have guessed that the Van de Graaff generator was much older. I ran into one as a teenager, and it was running in SF6, possibly an Ion Physics product- a 50 or 100kV portable power source used for powder coating. Now, of course, they're made with switching supplies and SF6 is avoided wherever possible since it's a very strong greenhouse gas (like 20-25,000 x worse than CO2). It's still used in some utility circuit breakers. \$\endgroup\$ Commented Aug 4, 2023 at 14:26
I have built many of them. The best designs spray a positive charge on the belt with a 15,000 VDC power supply. Both upper and lower rolls are aluminum with a steel drive shaft through their centers. I use fiberglass reinforced strap tape STICKY surface to STICKY surface to make a unitized seamless belt that requires very little driving power. The tape is available in 1” & 2” widths. Make sure your charge sprayer point is placed far enough to cause a purple glow. If you adjust to it close, it will arc and burn a hole through your belt and possibly damage the surface of your lower roll. The machined rolls should have a .04” crown on them.
I think that you are wrong. Friction of the belt and rollers makes the static electricity. I know that the pure triboelectric effect is based on contact but no one's Van de Graff has a perfectly tight and rolling Van de Graff. You can see it on electroboom's video. When he makes a perfectly rolling roller, his generator does not work. Sometimes it is better to use a stationary roller and check the triboelectric series and hope that your belt is being charged by your bottom roller and repelled by the top, or the opposite, charging the top roller caused by the friction of the belt.
Maybe wood is not a good material but as you can see everything is dirty there, clean your Van de Graaff meticulously with degreaser and try to first rub the materials yourself and check if they work.
  • \$\begingroup\$ Have a look here. That Van de Graaff machine has a bicycle wheel hub at the upper end. Besides rolling smoothly on bearings, it is smooth, conductive steel. The triboelectric effect doesn't require rubbing. \$\endgroup\$
    – JRE
    Commented Aug 4, 2023 at 13:46
  • \$\begingroup\$ Another one with bearings at the upper end. \$\endgroup\$
    – JRE
    Commented Aug 4, 2023 at 13:49
