I need to build a device, which measures several parameters (body temperature, conductivity and pulse) and transmits them to an Android mobile device.
The system has following parts:
- The sensors
- Sensors -> logic unit connection
- Main logic unit
- Main logic unit -> Android device connection
I intend to use IOIO Mint as the main logic unit and Bluetooth as "Main logic unit -> Android device connection".
Now comes the problem - I need to place the sensors close to the human body such that they are easy to wear. Probably, the sensors will be located at a different part than the main logic unit (the former - attached to the skin, the latter in a pocket).
Ideally, the sensors would have a wireless connection to the main logic unit or to the Android device.
My first idea was to connect the sensors to FLORA, add a BlueTooth module to FLORA such that FLORA communicates with the Android device directly. But AFAIR there is no good-enough support for BlueTooth on FLORA.
Are there any other ways to transfer data from sensors to main logic unit or to an Android device (except BlueTooth, wires and conductive textiles) ?
