I have a BLDC motor with Hall connections Hu, Hv, Hw and U, V, W. I am looking at a driver for the BLDC motor, but the driver has hall connections HA, HB and HC. Are Hu, Hv, Hw and HA, HB, and HC the same? Can I use this driver to run my BLDC motor?
2\$\begingroup\$ Yes, they are the same. \$\endgroup\$– DKNguyenCommented Feb 16 at 4:38
\$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$– Community BotCommented Feb 16 at 5:33
Add a comment
1 Answer
yes both are same you can go ahead with this
\$\begingroup\$ Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center. \$\endgroup\$– Community BotCommented Feb 16 at 5:34
