I have a battery pack for a circa 2008 Black & Decker 9.6 V electrical screwdriver. It was not holding a charge so I replaced its batteries. It had eight NiCd 1200 mAh batteries. I replaced them with new NiMh 1500 mAh ones (these were available to me). I charged them with the original charger for 6 hours. I measured the battery pack open circuit voltage at 10.96 V afterwards.
Next day I repeated the measurement, and it was 10.75 V. I never used the device and in fact, did not install the battery pack on the device.
  • Measurement two days after charging: 10.65 V
  • Measurement five days after charging: 10.56 V
Is this normal for the type of batteries used?
  • \$\begingroup\$ You have also replaced the batteries with ones of different chemistry. The voltages and charge profiles are different. I don't know what the charging circuitry is but it's probable that it was not designed to deal with NIMH batteries. \$\endgroup\$
    – vir
    Commented Mar 8 at 19:16
  • \$\begingroup\$ @vir I appreciate your comment, but I honestly do not see how the charger could be presented as a factor. The NIMH batteries do not know how they are being charged. I am assuming the charger is providing a 'standard' charge for 6 hours. I don't think the charger has any intelligence to it. And I don't believe there are specialized chargers for NIMH batteries. Such batteries also do not have BMS components designed for them. I am not well-versed in 'constant voltage, constant current' knowledge, but the three phase charging of lead-acid batteries probably does not apply here. \$\endgroup\$
    – Sabuncu
    Commented Mar 9 at 6:49
Nickel metal hydride batteries have a relatively high self discharge rate. Battery University says that they lose 10 to 15 percent of charge over the first 24 hours. That loss of charge will result in a lower battery voltage.
BU provides this self-discharge rate diagram for nickel based batteries:
Note that the diagram is charge state, not voltage. Voltage is related to charge state, but not in a simple way. About all you can say is that lower charge means lower voltage.
In other words:
Yes, it is to be expected that the voltage slowly drops with NiMh batteries.
  • \$\begingroup\$ Much appreciated. I was thinking that the batteries might somehow be bad. \$\endgroup\$
    – Sabuncu
    Commented Mar 8 at 10:27
