Question
On a board-to-board connector, can the shield pins be used as power pins to carry bus voltage, or should shield pins always be tied to return?
Specific Connector
In my specific case, the connector pair are low-profile mezzanine connectors (plug, receptacle).
The datasheet specifies:
i.max.signal = 0.3 [A]
i.max.power = 5.0 [A]
however, the datasheet nor the drawing specify a power pin.
The manufacturer provided symbols/footprints are as follows:
Plug:
Receptacle:
Note that the plug specifies the end pins as power pins whereas the receptacle specifies the end pins as shield pins. The manufacturer responded for clarification that the 'fixturing pins' are the high current rating power pins advertised in the datasheet.
The manufacturer provided a diagram of the fixturing pins as well:
Specific Case
I have 3x dc bus voltages:
V1 = 4.0 [V], 1.50 [A.max]
V2 = 3.0 [V], 0.50 [A.max]
V3 = 3.8 [V], 0.25 [A.max]
RTN = 3.8 [V], 2.25
They share a return. The max voltage anywhere near them will be 12 [V].
The connector is current-rated as:
5.00 0.30 0.30 0.30 5.00
[P1] [11] [12] [13] [P2]
[ ] [21] [22] [23] [ ]
0.30 0.30 0.30
I thought I could hook it up with currents such that:
1.50 0.25 0.25 0.25 2.25
[V1] [V3] [V2] [V2] [RTN]
[ ] [V3] [V2] [V2] [ ]
0.25 0.25 0.25
