I am trying to find a replacement for this capacitor taken from a Haier aircon unit fan motor circuit. The combination of specifications (μF, volts, size) are not currently listed on the Nichicon website, so I guess it was discontinued. The closest models I can find have a slightly different connector, meaning a similar replacement doesn't fit the PCB.
The markings are: Nichicon CE 105'C GG(M) 820 μF 450 V C1713 B17-037179
The GG(M) is the LGG range specified here, but they don't go up as high as 820 μF in 450 V, only to 680 μF.
The closest I can find specs-wise is in the next size down: LGL2W821MELC50 which I have purchased, but the “snap in” connectors are not the same.
I can't seem to find other connectors listed here which match the 90 degree turned style with the wider tabs and two prongs,
I've also looked through many suppliers like Mouser, Farnell, RS, etc. using the parametric search to find other connector names, but none seem to match this. The closest is the four-prong motor start caps.
