I'm designing a system for a high-vibration application. I need to land wires on circuit boards. Someone suggested that I use a Wago cage clamp, and that there might be similar things from other manufacturers. The cage clamp was described as useful for this application because the more the wire pulls, the tighter the clamp becomes.
I'm thinking that this might be the same as a spring cage, tension clamp connector. Is it? Is either of these things the "correct" terminal to use for this kind of application?
added: Vibrations are 0.4g peak-to-peak @ frequencies up to 100 Hz
