My circuit consists of two oscillators: one VCO in audio range and an LFO (low frequency oscillator - below the audio range). The signals from the two oscillators are amplified with two non-inverting op amp amplifiers. The two amps (LM358) share the same split voltage supply/virtual ground source. Because of that the LFO effects the frequency of the VCO. The two oscillators should be entirely independent. How can I avoid the two oscillators effecting each other?
