I'm currently working on designing a circuit that will utilize two piezoelectric stacks (5mm x 5mm x 20mm Parker stacks) that are loaded into a housing in parallel mechanically. The circuit I'm trying to design will be a pressure sensor that utilizes those two stacks the way to measure the dynamic pressure and I have examined some circuits that utilize piezoelectric diaphragms (eg: Piezoelectric Sensor and the ADC), but I am unsure of whether or not the same kind of circuit would be applicable to piezoelectric stacks.
Some of the other circuits I've seen utilize diodes, while others utilize capacitors, and all of them utilize some type of op-amp (I was thinking of using the TLV2771) so I am kind of at a loss of what the best way to design this circuit would be.
