I'm looking to observe magnetizing offsets of various current sensors. The idea is that when you pass a high current pulse (close to the rating of the device) through a current sensor and then return the current to zero, there is some small offset in the device. This is due to some polar magnetization of the core inside of the sensor.
My issue is that some of the devices are rated for 200 amps. I would like to somehow create a current source circuit that is able it apply 50 amps for short duration pulses (20 milliseconds or so). I would fool the sensor into thinking its 200 Amps by wrapping the wire in loops so that it passes through the center of the sensor 4 times.
Note: the reason I cannot do 2 amps and 100 turns (example) is because the wire size begins to stack up and will not fit inside the sensor.
Does anyone have any ideas on this, or can redirect me to a post about this?
