Basically, I need to monitor a circuit's output so I can activate another system. The output voltage of active stage is 140mV.
If I am not wrong (from what I read about transistors) 140mV is not enough to put a BJT transistor into saturation (ON mode).
The end goal is turning on an LED and/or a relay, so I really need transistor in the saturation region.
I don't want to use a micro-controller's ADC to measure the voltage for such simple device (cost wise)
How can solve the problem in a simplest manner possible?
    \$\begingroup\$ Is the output AC or DC? \$\endgroup\$ Commented Sep 14, 2014 at 19:11
    \$\begingroup\$ it is DC 140mV output \$\endgroup\$ Commented Sep 14, 2014 at 19:19
Use a comparator.
Just be sure to get one with an input common-mode range that extends down to the negative rail. TL331, for example, might work for you.
  • \$\begingroup\$ Thanks, it is good to learn something new. just to be clear, lets say I power the comparator with 5v and connect Input- to ground and Input+ to other circuit. Will the output be 5V when Input+ goes to 140mV? \$\endgroup\$ Commented Sep 14, 2014 at 19:37
    \$\begingroup\$ The output is open-collector. So you have to provide a pull-up resistor. The benefit is the output high level is whatever you connect the pull-up to, and it doesn't have to be the same as the supply voltage. \$\endgroup\$
    – The Photon
    Commented Sep 14, 2014 at 19:48
  • \$\begingroup\$ Note you should set a threshold for Input- that's slightly above ground (say 100mv), or it'll be 'on' all the time. Also you need to check that your comparator can actually handle inputs that close to the rails. \$\endgroup\$
    – pjc50
    Commented Sep 14, 2014 at 20:14
  • \$\begingroup\$ I found TL331's PSpice library, I will try to run some simulations (Planning to learn spice anyway). Thanks for helping \$\endgroup\$ Commented Sep 14, 2014 at 20:17
