My first post here, please keep in mind that I hardly know anything about electrical engineering so please keep any replies in layman terms, thank you!
I bought this 30cm white LED strip.
It's set up to run from 12 volts. The thing is I would like to use it at 6 volts. I can see that there are soldered IC chips on it: an M7 chip and a 78L05 chip; from what I could find out the 78L05 chip is a voltage regulator.
What would be the simplest way to get this to run from 6V?
