I am using 'pickit2' through Mplab to burn my code. Suddenly none of the codes (even blinking led) that I fuse through it gets executed.
I confirmed whether it writes the hex code properly using the 'Read Memory' feature. On comparison, I found no change in the hex.
I changed lot of IC's (16f/18f), I tried other boards too, but nothing worked.
What's going wrong with my setup? please help me to figure it out.
