I am working on an application that requires isolated power inputs.
Wondering if the standard ATX PSU has any isolated outputs?
Why are we having multiple ground pins on the Connector?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI am working on an application that requires isolated power inputs.
The outputs of the ATX power supply are isolated from the mains. The outputs of the ATX power supply are not isolated from each-other. In other words, +5V and +12V output "share" the same ground.
Multiple ground pins increase current carrying capacity. I bet, you will see continuity between them if you check with a meter.
My information comes from several ATX power supply reference designs that can be found on the web (such as this one). Such reference designs contain detailed schematics. A complete schematic would be a bit too detailed for the purposes of this conversation. But here's a block diagram.
Per this link, the ATX provides isolation from the wall power supply. But their outputs share a common, the link also gives the simplified circuit of a PC PSU.
And the ATX standard defined the connector pin-out. There are many "COM"s on a connector, beside the reason for interconnecting, there are reasons to increasing the current carrying capability. Because connectors usually has a rated current carrying per contact, if your output current greater than this, you need more contacts.
Refs:
