Could somebody please please help me understand the following code. Its running on atmega128 @ 16 Mhz. Its reading an encoder pulse. Uses timer3. The encoder CHA is connected to PIND2 (INT2) which gets triggered whenever there is an interrupt from low to high. CHB of the encoder is connected to PINE7.
I cant quite understand why TCNT3>>3 in this case.
SIGNAL(SIG_INTERRUPT2)
timer3_stop();
Right_Odometer_Period = TCNT3>>3;
right_overflow_occurred = timer3_overflowed;
timer3_start();
if ((PINE & 0x80) != 0)
right_odometer++;
right_up = 1;
else
right_odometer--;
right_up = 0;
Right_Odometer_Period = Right_Odometer_Period * -1;
Right_Velocity = Right_Odometer_Period;
averaging_array[array_ptr++] = Right_Odometer_Period;
if (array_ptr == 32)
arraysum = 0;
for (int i = 0; i<32; i++)
arraysum += averaging_array[i];
average = arraysum>>5;
array_ptr = 0;
void timer3_init(void)
TCCR3A = 0x00;
TCNT3 = 0X0000;
ETIMSK = (ETIMSK | (1<<TOIE3));
timer3_start();
void timer3_start(void)
TCNT3 = 0X0000;
timer3_overflowed = 0;
TCCR3B = (1<<CS30)|(0<<CS31)|(0<<CS32);
void timer3_stop(void)
TCCR3B &= ~(1<<CS30)|(1<<CS31)|(1<<CS32);
SIGNAL(SIG_OVERFLOW3)
TCNT3 = 0X0000;
Right_Velocity = 0;
timer3_overflowed = 1;
