Found a switch for a project, and want to make sure I understand it correctly.
This is the switch: (Mini-Circuits SWMA-2-50DR+).
Now, it has a TTL driver circuit with the inputs +5V, -5V, and TTL IN. The TTL IN has low threshold 0-0.8V and high threshold 2-5V.
Will it be possible to control the switch with a microcontroller that alternates its output between 0V and 5V, and is directly connected to the TTL IN input? Or is it necessary with some kind of circuit in between?
