I can't twist my head around the proper use of my latching switch problem. In detail, the latching (or maintained) switch should switch a 48V DC source power supply for a cisco router. The 48VDC power supply is hooked up to 230V AC.
Ideally, you would push the button -> it should be "ON"; providing 48VDC to the device. you push the button again -> it should switch "OFF"; no power to the device.
now comes the logic: if the power supply on the 230V side doesn't have power, the maintained switch should be "reset" to off; meaning that if it's in "ON" position but you unplug the electricity cable; the maintained switch should get back to its "OFF" position.
I guess this problem has been solved many times, but I am not sure what kind of schematic I am looking for, i. e. what's the name of this circuit or is there a device capable of doing exactly that?
