I want to make a traffic light circuit but the problem is that I don't have a 0.1µF capacitor. I do have a 1µF capacitor, would it be OK to replace it?
The circuit diagram I am using is shown below and is taken from an online tutorial:
Seeing how it is across the 9V supply rail it is just decoupling for the power supply rail. Better designs (as most people here would be quick to point out) would have a decoupling cap local to each Vcc pin per IC, but for a simple design like this, one cap across the rail is probably fine. Using a 1uF cap is okay. Just make sure it is rated for >9V. Safest bet would be 16V caps, 10V is cutting it close.
Truthfully this design would probably work with no cap too, you might just experience weird glitches every once in awhile if the power supply blips from sudden current demand changes.
Yes, you can replace the 100 nF (in engineering you keep 1-3 digits left of the point and adjust the units multiplier accordingly) with a 1 µF, but only if it is low ESR (equivalent series resistance).
The 100 nF you show is almost certainly a ceramic or some other type with very low ESR. Replacing it with a 1 µF electrolytic is not a good idea because this single cap is apparently also the bypass cap for the two ICs. This means it must be able to shunt the high frequency power currents generated by the ICs.
The right way to do this is to put a 100 nF to 1 µF or so ceramic cap immediately across the power pins of each IC. That shunts the high frequency power currents generated by the ICs immediately around the IC. This does a better job than a single cap for the whole board because of the lower series parasitic inductance in the shorter leads to the cap, and will radiate less due to the smaller loop size.
It's unclear exactly what the designer intended the 0.1uF capacitor for, but it would be very common to have a 0.1uF (100nF) capacitor across the power rails of each IC for decoupling.
There would usually be a 0.1uF capacitor for both the 555 and 4017 ICs, close to the power pins.
You could use 0.1uF and in this circuit it will likely work just fine (it might work fine without, why not try it?).
However you should probably buy a large pack of 0.1uF/100nF capacitors for use in the future because they will appear in most circuits.
No need of that 0.1uf. That's for power stability. You may avoid that capacitor.
