I power a DAC from SMPS. After the SMPS I use a LDO.
My problem is that most LDOs only have a good PSRR around 100 kHz or lower, while my SMPS has a switching frequency of about 1 MHz (thus noise).
1 MHz noise is not in the audio band....but my question is should I use a low pass filter before the LDO to filter that high frequency noise? Is it possible to have high frequency noise pollute the audio-band?
    \$\begingroup\$ I think it could be possible that the switching noise disturbes the audio, it depends on the DAC of course. But if you have to option to filter the SMPS noise then I would say: better safe than sorry and place the filter. You can always later replace the filter with a 0 ohm resistor and see how that works out. \$\endgroup\$ Commented Sep 29, 2015 at 9:08
  • \$\begingroup\$ Yes you should, and yes in the presence of sampled signals, yes it's possible. \$\endgroup\$
    – user16324
    Commented Sep 29, 2015 at 10:01
Not only can HF noise influence your signal, it will influence your signal.
Only if a signal is phase locked to another will they have no dynamic influence on each other. Since your SMPS will create either one fixed frequency, or at the very least one completely unrelated to the audio you are making (Fun idea to try and lock them maybe, but utterly infeasible), there will always be interference from that noise into the samples generated.
It is also why good, medium-high to high resolution mixed signal designs include completely separated digital and analogue power systems.
If you have a HF transient on the analogue power right between (sensitive) samples, such as made by an SMPS at 1MHz, or by a digital parallel (or serial) bus, the difference in the samples will jump up or down a bit. By how much would greatly depend on your DAC. Having any of those transients on the analogue reference voltage will most certainly have a sample-to-sample influence!
This HF noise may not propagate fully or "as-is" through your analogue system, but it will most certainly have an effect on the audio output if it has any remaining significance to it.
1/1000th on the power rail, or 1/10000th on the analogue reference should be your absolute maximum, in my opinion, but in all fairness that's just a touchy-feely judgement call from someone not specifically an audio engineer. So that may be off by a decade if you talk to an actual audio pro, just don't get caught into Audiophoolery trying to make noise μV per kV or some such.
As for filtering, that can be easy enough:
Here I chose to use a coupled inductor, because the total inductance for a noise signal through the coupled conductor will be much higher for smaller/cheaper inductors. You could add a chip-bead in series with it to eliminate very high frequency noise to a higher degree. You can also include a chip-bead with an extra 100nF to 1μF at each chip/device/stage that uses the power to also isolate any digital noise picked up in DACs and such, but in an audio system that's often going well and truly over-board.
The values in this schematic are a quick back-of-head estimate based on a simplicifation of the real part of the "resistance" each element adds to the system. You can go into transfer functions, but I used a 50μH total coupled inductance for the coil and came to:
Z(C) = 1 / (jwC), means for a quick estimation the apparent resistance for a capacitor will come close to: "R(C)" = 1 / (2*pi* C). Deeper theories apply, but that would make this answer take several hours I don't have right now.
Z(L) = jwL, comes to: "R(L)" = 2*pi* L.
Which gives:
C1 will present as nearly equivalent to a 0.72 Ohm resistance at 10kHz.
C2 will present as nearly equivalent to a 0.16 Ohm resistance at 10kHz.
A coupled (or single) inductance of total effective 50uH will present as nearly equivalent to a 3.1 Ohm resistance at 10kHz.
This means that a 10kHz signal will be attenuated by about a factor of 20 by the inductance + C2 stage alone. Basically C1 is just there to give the high frequency components close to the filter somewhere to go, but as you can see with a 0.5Ohm resistance in cables and such, it already helps to filter noise. A factor 20 in voltage would, if I am not mistaken, be equivalent to -26dB. At higher frequencies this will quickly snow-ball into -70dB or better.
For well chosen parts, up to several MHz, the resistance in the capacitors will be divided by each multiplication in frequency. So 0.072 Ohm for 100kHz for C1, etc. Whereas the "apparent resistance" of the inductance will multiply, so 31 Ohm for 100kHz, etc.
It is important to realise though, that at these low apparent resistances the ESR/DC-resistance of the components has a real influence. If the capacitors have 5 Ohm ESR, then the filtering will be severely limited, so you may want to make the 100uF capacitance a small group of smaller caps. Possibly including a couple of 1uF/100nF ceramics to really get the sting out of MHz level noise. Also take note that long winding wires or traces to the capactiors from the power will increase resistance and wire inductance, to again limit the filtering capability.
Of course, the 3dB point and the total suppression at frequency X or Y will be much better represented when using proper filter maths, but it's my work day and writing that all up would take too much time, where this comes close enough. Look up LC filtering tutorials or Q&A's for deeper details into the proper maths.
If you have a separate digital system that can be powered independantly from the analogue supply, it is best to "tap" that supply from the raw and noisy supply and filter it independantly. One reason is that the digital system will need much less filtering. Another reason is that then the digital transients on power will by separated from the analogue power by 2 independent L-C-filters.
Although you can see that having a simple 50Hz/60Hz transformer that already acts as a huge filtering coil to AC-transients makes filtering a very simple matter of 0.2 Ohm wire resistance and 10mF of capacitance to basically get no-noise. One of the reasons SMPS's have not been used in audio systems for so long. "Tried and true" argument.
Yes you should LC filter before the LDO if you want good sound .You dont want any HF crud getting into your audio system .The type of horrible distortion it causes is much more obnoxious to the ear than harmonic distortion.
  • \$\begingroup\$ One last doubt...some new LDOs have excellent pssr up to 1Mhz .Do you still recommend LC filter in this case ? \$\endgroup\$
    – Johan B.
    Commented Sep 29, 2015 at 9:33
    \$\begingroup\$ YES ! The LDO might suppress upto 1 MHz, but do the SMPS spurs stop at 1 MHz ? Nope :-( I once worked on a project where the 283rd harmonic (!!!) of an SMPS was causing trouble ! \$\endgroup\$ Commented Sep 29, 2015 at 9:39
  • \$\begingroup\$ Yeah, all sounds about 200kHz just make my ears bleed when I hear them coming out of poorly filtered equipment... \$\endgroup\$
    – PlasmaHH
    Commented Sep 29, 2015 at 12:14
