I have a question regarding switch debouncing I'm using a PIC12F509 and the internal RC oscillator operating at 4 MHz.
I'm toggling an LED on and off connected to GP1 (output) via a momentary push button switch on GP3 (input) which is held high via a 10K resistor when the switch is open. I'm using the following macro and the code below to debounce the push button switch. It utilizes timer 0 set to a 1:256 prescale.
It waits until the contacts have remained in the same state (open in this case) for 10 milliseconds before executing the rest of the code. If they bounce (go low) timer 0 gets reset.
DbnceHi MACRO port,pin
local start,wait,DEBOUNCE
variable DEBOUNCE=.10*.1000/.256 ; debounce count = 10ms/(256us/tick)
pagesel $ ; select current page for gotos
start clrf TMR0 ; button down, so reset timer (counts "up" time)
wait btfss port,pin ; wait for switch to go high (=1)
goto start
movf TMR0,w ; has switch has been up continuously for
xorlw DEBOUNCE ; debounce time?
btfss STATUS,Z ; if not, keep checking that it is still up
goto wait
ENDM
main_loop
; wait for button press
wait_dn btfsc GPIO,3 ; wait until button low
goto wait_dn
; toggle LED
movf sGPIO,w
xorlw b'000010' ; toggle shadow register
movwf sGPIO
movwf GPIO ; write to port
; wait for button release
DbnceHi GPIO,3 ; wait until button high (debounced)
; repeat forever
goto main_loop
END
Now onto my question up until now I've been debouncing both the button press and release. It's been brought to my attention in the tutorial I'm following that it's not normally necessary to debounce both the press and release of a switch.
I can understand why in theory because after the switch is read as low via the btfsc instruction (even if it's momentarily because the contacts are bouncing). The LED is toggled and the debounce high code will wait until the contacts have opened and stopped bouncing before executing the goto to loop the code from the beginning.
On the positive side this saves program memory. But if something seems too good to be true it usually is what are the potential pitfalls using this method?
Obviously for a simple application like this the code is overkill. But for something more critical like putting the PIC in sleep mode and waking up from a pin change any bounce must be eliminated in order for the micro to enter the leave sleep mode reliably.
What are your opinions on switch debouncing do you debounce the press and release or only one?
My guts telling me to go belt and suspenders and just debounce both to be safe but I have no logical reason for it.
