Absolutely not.
The voltage rating is generally based on safety concerns and insulation properties. The current rating is based on the wire construction (thickness), and heat dissipation properties.
For a switch, even the AC and DC properties might not be the same, as any arcing that occurs in an AC use is quenched 120 times/s, while in a DC situation it is not.
Generally less than 40 V or so is reasonably safe for bare contact with one hand, but you would certainly feel 40 V if you touched it with wet skin (I wouldn't try it) -- you might even feel 9 V.
