Let I1 be the current through R6, V3, and R7 Let I2 be the current through R5, and V2 Let I3 be the current through R4
Suppose I did not know V2 = 36.4V, but I know the voltage across R7 is 15V.
How do I figure out V2 ?
Here is my KCL =
I2 = I1 + I3
KVL
30I1+25 + 50I1-V2 + 20I2 = 0
-20I2 + V2 -75I3 = 0
When I solve the above 3 equations I get V2 = 25, not 36.4. What am I doing wrong?
  • \$\begingroup\$ I1 is not the same for R6, V3 and R7. The sum of currents for V3 and R7 is equal the current through R6. \$\endgroup\$
    – vini_i
    Mar 25, 2016 at 1:16
Your equations are wrong. The \$V_3\$ branch is not considered since the switch is open. If the switch was open, you would then have 3 loops in total, and \$I_1\$ would be split.
Following your assumptions about the currents:
$$I_2 = I_1 + I_3$$
\$I_1\$ can be gotten right away since you somehow know that the voltage across \$R_7\$ (top to bottom) is \$15 V \$.
$$I_1 = 15/50 = 0.3 A$$ $$I_2 = 0.3 + I_3 ............(1)$$
The equation for the first loop is:
$$-20I_2 - V_2 - 75I_3 = 0$$ $$20I_2 + V_2 = -75I_3..........(2)$$
The equation for the second loop is:
$$80I_1 + V_2 + 20I_2 = 0$$ $$24 + V_2 + 20I_2 = 0$$ $$20I_2 + V_2 = -24............(3)$$
Equating (2) and (3) gives:
$$-24 = -75I_3$$ $$I_3 = 0.32 A$$
From (1):
$$I_2 = 0.3 + 0.32 = 0.62 A$$
From (3):
$$V_2 = -24 - 20I_2 = -24 - 12.4 = -36.4 V$$
Meaning, the polarity of \$V_2\$ in your schematic is the other way round.
