I've solved for all of the currents in the circuit (I used an equivalent resistance for the middle two resistors) and the current through the 6V battery is 0 A. If there is no current through this battery, can it supply a voltage drop across the rightmost 600 ohm resistor? In other words, in this circuit, what is the voltage drop across the rightmost 600 ohm resistor?
