I have a problem, found on both ATMEGA1284P and ATMEGA2560.
I have set a 16-bit timer in CTC (tried both Timer1 and Timer5) to give an interrupt every 1ms so I can increment a 32-bit volatile time variable. At the same time, I am sending and receiving data using UART1 and UART2.
This works for some time, however, after exactly 1 min and 6 seconds (~65500 ms ~= 2^16 ms), my UART1 stops working. UART2 and everything else is still working as expected. When I disable my timer, UART1 keeps working.
I would highly appreciate any help. I have posted my initialization code, let me know if I can provide anything else to find a solution.
UART1 Init code:
#define F_CPU       16000000UL
// (I have also tried disabling the 16 MHz clock and fall back
// to the 8 MHz clock, setting OCR1A to 0x03EF, with no success)
void uart1_init() {
    uint16_t baudrate = UART_BAUD_SELECT(BAUD485, F_CPU));
    UBRR1H = (uint8_t)(baudrate>>8);
    UBRR1L = (uint8_t) baudrate;
    // Clear USART Transmit complete flag, normal USART transmission speed
    UCSR1A = (1 << TXC1) | (0 << U2X1);
    // Enable receiver, transmitter and receive interrupt
    UCSR1B = (1 << RXEN1) | (1 << TXEN1) | (1 << RXCIE1);
    // Asynchronous mode, no parity, 1 stop bit, character size = 8-bit
    UCSR1C = (1 << UCSZ11) | (1 << UCSZ10) | (0 << UCPOL1);
// somewhere later: sei();
Timer1 code:
volatile uint32_t time = 0;
void timer_init(void) {
    // This code sets up Timer1 for a 1ms @ 16Mhz Clock (mode 4)
    OCR1A = 0x07CF;
    // Mode 4, CTC on OCR1A
    TCCR1B |= (1 << WGM12);
    // Set interrupt on output compare match
    TIMSK1 |= (1 << OCIE1A);
    // Set prescaler to 8 and start the timer
    TCCR1B |= (1 << CS11) ;
ISR(TIMER1_COMPA_vect) {
    // Action to be done every 1 ms
    // Problem also occurs with empty interrupt
    // What I should have here: time++;
  • \$\begingroup\$ Do you have a debugger that you can use to pull the register values of the UART before and after the error state? \$\endgroup\$
    – Daniel
    Commented Jun 25, 2016 at 5:11
  • \$\begingroup\$ Unfortunately not with my hardware no. Both are custom built PCBs with ISP only. (or is that possible with ISP and I'm unaware of it?) I might be able to transmit the values over the working USART2. I will try that later and report back. \$\endgroup\$
    – Johis
    Commented Jun 25, 2016 at 5:16
  • \$\begingroup\$ Possibly/probably? I haven't used AVR in a while, but the one-wire debug was always a big bonus. \$\endgroup\$
    – Daniel
    Commented Jun 25, 2016 at 5:26
  • \$\begingroup\$ You should be able to use debugWire to debug the thing, yeah... \$\endgroup\$ Commented Jun 25, 2016 at 6:09
    \$\begingroup\$ Probably more like it stops after exactly 65535ms, which implies something is overflowing somewhere. We need to see the rest of your code - the problem does not lie with what you have shown us. \$\endgroup\$ Commented Jun 25, 2016 at 14:01
Check the fuse bits, in ATmega128 I was facing the same problem. For Atmega128 the fuse bits are C4, D9, FF, FF for Low fuse, High Fuse, Extended Fuse and Lock fuse respectively.
    \$\begingroup\$ How do these fuse settings relate to the problem at hand? Without an explanation, this is little more than a comment. \$\endgroup\$
    – Dave Tweed
    Commented Jan 29, 2017 at 12:59
  • \$\begingroup\$ I can also not see how the fuses should have been the problem. As you can see above, I "solved" the problem by changing to another (identical) ATMEGA chip. However, I still have no idea what caused the problem. The fuses I have changed from non stock are: remove CKDIV8, BOD to 4.3V, enable external crystal and disable JTAG. \$\endgroup\$
    – Johis
    Commented Jan 29, 2017 at 15:18
