A 3 phase fully controlled bridge converter is fed through star-delta transformer. The converter is operated at a firing angle of 30 degrees. Assuming the load to be a RL load and load current to be virtually constant at 1 pu and transformer to be an ideal one, how will be the input phase current waveform look like ?
Edit:
I was expecting the following result
but to my surprise the answer is the following waveform.
Definitely I'm making some mistake, please tell me how the waveform came.
    \$\begingroup\$ This has a very strong smell of homework with no attempt at solving. Show your work and explain where you are stuck. \$\endgroup\$
    – Transistor
    Commented Jul 28, 2016 at 8:12
  • \$\begingroup\$ Can you start by providing a schematic? (I love schematics!) \$\endgroup\$
    – Mark
    Commented Jul 28, 2016 at 9:13
  • \$\begingroup\$ This was not a homework, but yes I was unable to get the answer. \$\endgroup\$
    – Vedanshu
    Commented Jul 29, 2016 at 9:28
