On the datasheet says minimum Upper Switch Current Limit at minimum duty cycle is 4.0A (min) 5.8A (typ).
How can i calculate the maximum output current? It will be higher or lower than 3A?
Datasheet 1st page says
3A Continuous Output Current
4A Peak Output Current
The peak current is usually limited by choice of L and IC heat loss and is exceeded by upper switch max current capacity.
  • \$\begingroup\$ 4A peak putput current can not be prolonged? \$\endgroup\$
    – Bruk
    Commented Sep 13, 2016 at 6:33
  • \$\begingroup\$ NO compute thermal junction rise \$\endgroup\$
    – D.A.S.
    Commented Sep 13, 2016 at 6:39
In theory you could get 4-A output current, assuming very large heatsink pad and inductance enough large to minimize current ripple. But maximum duty cycle is 90 %, so there will be also switching at 340 kHz and total losses will probably overheat the poor IC. Nobody uses components at their maximum ratings, even if it would work.
