I would be grateful for assistance in identifying an old motor from Matsushita Electric Industrial Co. Ltd. I have been unable to find a datasheet for the motor. An image of the partially disassembled motor is included below. I am able to take more specific pictures if requested and directed. The text reads:
IB30-16.5
4P 30W
220V 50Hz 3.5uF
240V 50Hz 2.8uF
The cylindrical case has an outer diameter of 90mm and height of 110mm.
I assume this is a single-phase four-pole motor. I would be grateful for guidance in determining whether the capacitances listed are for start capacitors or run capacitors, and which of the three wires - white, brown, black - is which.
I have measured resistances and inductances. The resistances were measured directly with a multimeter. The inductances were measured by driving a square wave through the windings in series with a known resistance of 270R, and measuring the RL time constant from the captured waveform. The results were as follows:
white to brown: 210R 127mH
white to black: 94R 87mH
brown to black: 120R 94mH
In calculating inductance via the resistance and time constant, I summed the 270R and winding resistance and multiplied by the time difference between the peak of the waveform and 0.37x that peak with respect to the waveform's minimum value.
I believe that the winding with the largest inductance is the main winding. I also believe that the winding with the highest resistance tends to be the auxiliary winding, but this makes the results contradictary. However, I could understand a lower resistance for the auxiliary if it is substantially shorter.
I hope my inexpert research can help an expert to answer my questions on capacitors and winding identification. I would also welcome any corrections, especially if I am way off base!
Thanks for considering my question.
