Does anyone have experience with using a 50 Hz, 220 VAC solenoid valve for 220 VAC/60 Hz? It definitely will work, however, is it safe/reliable in the long term?
The model of solenoid is ASCO 307 series, however, I belive this question will apply to any solenoid/relay.
With solenoid operated current will be due to inductance + coil resistance.
An important point from Andy's answer is that if significantly increased core saturation occurs due to the lower frequency then a substantial drop in impedance and increase in current may occur. My following comments apply IF the core does not saturate significantly more at 50 Hz than at 60 Hz - and it may.
Whether saturation increase is significant or not, and how to tell:
Solenoids tend to have some degree of airgap present due to imperfect mechanical closure at the 'striking face' and the existence of an air-gap between slider and stationary core. If desired these airgaps can be designed to be very small, but usually this is not a major requirement. The result is that solenoids may often be somewhat more tolerant to core saturation than transformers that have no or small well designed airgaps.
But, this is not certain and needs to be checked.
An "easy enough" check for core saturation increase is to measure operated current at 50 Hz and rated voltage and compare this with that specified for 60 Hz. If the increase is less than about 15 to 20% then the effects that I describe below are mainly involved. (You can calculate the likely current with no saturation change using my procedure described below.) If the increase is above or well above 20% then saturation is probably occurring significantly. In such cases a suitable series resistor that brings solenoid AC current closer to the desired range may be in order.
Current at 50 Hz will be greater than at 60 Hz due to lower impedance of inductor. This can be as much as 60/50 = 20% higher but will be somewhat less than this due to the coil resistance. Main losses will probably be I^2R losses in coil resistance and these will be up to 40% higher due to I^2 term.
Extra thermal losses may be OK depending on ambient temperature, enclosure and manufacturers ratings. Usually I'd expect it to be "probably OK but it may not be. look at resistance and rated operating current - which will show you what the effective resistance is to AC so how much the inductor is affecting things.
eg made up example.
Voperating = 220 VAC.
Ioperating = 100 mA.
Rcoil = 1000 Ohms.
So effective "AC resistance" = V/R = 220/0.1A = 2200 Ohms.
Coil impedance will be the vector sum of R + L impedances.
R_AC_effective = 2200 Ohm
R_R = 1000 Ohm
R_AC_coil = sqrt(Zl^2 + 1000^2) = 2200
so Zl = sqrt (2200^2 -1000^2) = 1960 Ohms.
So Zl 60Hz = 1960.
Zl 50 Hz = 50/60 x 1960 = 1633 Ohms.
Rcoil_AC_50Hz = sqrt(1633^2 + 1000^2) = 1914 Ohms AC.
I increas = 2200/1914 = 1.15x = 15%.
Power increase = 1.15^2 = 32%.
Prior power in Rl = R x I^2 = 1000 x 0.1A^2 = 10 Watts.
New power in Rl ~= 13 Watts.
Q: Does it matter?
A: Probably not, but, it may.
As above, if significant saturation is occurring then the current increase will be above that figure.
If current increase is more than 20% then saturation is definitely occurring (as 20% increase is the maximum with a purely inductive coil and no saturation).
A series resistor can be added to reduce current as desired - with possible affect on operation needing to be watched for with increasing values of resistance.
Any AC wound component designed to work at 60 Hz CANNOT be assumed to work properly at 50 Hz. Core saturation is the big thing here. With the lower frequency, more current will be taken and the core may indeed saturate significantly. This may produce too much heat and losses that results in a shortening of the device's lifespan.
Ask your self why someone designing a solenoid for 60 Hz would put more metal into the core to ensure it works fine at 50 Hz. If the data sheet says it will work then that's another issue BUT as a piece of general advise, you cannot assume it will.
Also, at 50 Hz it may just begin to produce 50 Hz audible sounds - the solenoid armature is mechanical and has inertia and at 60 Hz it may be a lot quieter than it is at 50 Hz.
  • \$\begingroup\$ Good point re saturation (of course). After seeing your answer I've added a longish section to my answer on saturation and how to check whether it is significant. A possible "answer" to your "why would anyone ...?" is that they probably wouldn't in most cases, BUT the nature of a solenoid with inherent air gaps is means that they are likely to work "reasonably well" at 50 Hz than are most transformers. | I long ago specified a custom transformer for use in Taiwan on 220V but 60 Hz. I said it was for use in Taiwan but did not specify 60 Hz operation. The transformer winder ... \$\endgroup\$
    – Russell McMahon
    Commented Feb 13, 2017 at 10:44
  • \$\begingroup\$ ... "knew his stuff" and would it for 60 Hz operation. When trialled in NZ at 50 Hz it ran very hot. In Taiwan it worked correctly. (It got carried as checked luggage as part of a tester that I built.) This was for testing exercise machines able to handle up to 500 Watt electrical loads - so it was probably rated in the 500 - 750 VA range. \$\endgroup\$
    – Russell McMahon
    Commented Feb 13, 2017 at 10:47
  • \$\begingroup\$ @AndyAka, could we conclude that going in the inverse direction would be safe, ie. using a 50Hz solenoid on 60Hz power? I asked that question here: electronics.stackexchange.com/questions/642599/… \$\endgroup\$ Commented Nov 15, 2022 at 20:02
  • \$\begingroup\$ @Jean-FrançoisBeauchamp I saw that question and didn't answer but yes, I'd be tempted to believe it would be OK. \$\endgroup\$
    Commented Nov 15, 2022 at 20:06
solenoid, has linear movement when energized, A solenoid usually consists of a coil and a movable iron core called the armature. The electric supply is mainly to energize the armature to create a magnetic flux, so your solenoid would work fine.
Since the rated voltage is equal and small difference is frequency, you can try applying the 220V/60Hz supply without damaging it. Possible there might be a small jitter, due to frequency mis match
