I recently bought a 6 can fridge cooled with a tec1-12705 unit, meaning the current rating is 5 amps. It gets about 7 degrees C inside the fridge and I want to upgrade it. I've been searching for a better cooling unit. Would a tec1-12708 for example, give better cooling results, if the voltage and amps are the same as my power supply?
1\$\begingroup\$ Link to data sheet, please. \$\endgroup\$– Brian CarltonCommented Feb 18, 2017 at 21:32
2\$\begingroup\$ If you want more cooling with less power, look at compressor fridges like the Danfoss BD35. \$\endgroup\$– user16324Commented Feb 18, 2017 at 22:57
\$\begingroup\$ The Peltier effect is very inefficient, may I suggest you add more insulation instead? Increasing thermal resistance will most likely lower the temperature in the inside the fridge AND increase efficiency. \$\endgroup\$– user1890202Commented Feb 18, 2017 at 23:00
1 Answer
There is a lot of difference in the various peltier devices. You could go here and compare what you have in your cooler and find a unit that supports a higher performance.
In all probability you could substitute a Tec1-12708 device, though be aware that the thickness of the various devices in the same size family will vary. Even 0.5mm can be important where you need to provide the correct pressure from the heatsinks on each side.
If you did replace a 12705 with a 12708 you would have to ensure that the wiring and any temperature regulator (if you have one on the cooler) or fuse would support an increase from around 5 A to greater than 8 A.
