Using an STM32F429I-DISCO board. SYSCLK is set to 180 MHz. I verified the value from MCO2 output pin, and it is spot on. Setting up GPIO_AF3_TIM9 channel 1, and need an output of 12.288 MHz and 50% duty cycle. Calculated config values as:
const uint32_t TIMF = 180000000;
const uint32_t TFOUT = 12288000;
uint16_t ARR = (TIMF / TFOUT) - 1;
uint16_t uhPrescalerValue = ((SystemCoreClock) / TIMF) - 1;
uint16_t pulse = ARR/2 + 1;
Results are prescalar = 0, ARR = 13, pulse = 7.
Here is the setup code:
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF3_TIM9;
GPIO_InitStruct.Pin = GPIO_PIN_CHANNEL1;
HAL_GPIO_Init(GPIOE, &GPIO_InitStruct)
TimHandle.Instance = TIMx;
TimHandle.Init.Prescaler = uhPrescalerValue;
TimHandle.Init.Period = ARR;
TimHandle.Init.ClockDivision = 0;
TimHandle.Init.CounterMode = TIM_COUNTERMODE_UP;
if(HAL_TIM_PWM_Init(&TimHandle) != HAL_OK)
Error_Handler();
sConfig.OCMode = TIM_OCMODE_PWM1;
sConfig.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfig.OCFastMode = TIM_OCFAST_DISABLE;
sConfig.Pulse = pulse;
if(HAL_TIM_PWM_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
Output on scope counter shows PWM frequency as 12.8582 MHz. Duty cycle is correct. Where have I gone wrong in deriving the parameters?
