I'd think that switching a relay with 120V AC at the coils would not work due to this: https://gyazo.com/2a26aab1dbc70d3da16d0e5e31f1e759
Is that correct? If so, does that also mean 48VDC is the max voltage the coils of this relay can handle?
What I'm trying to do is switch on/off a small current using a larger one, so that a microcontroller can detect when it is on or off. Is there a easy/cheap way of doing this? Thank you.
