I have a mac and am looking for some instructions/tutorials on how to start using the Bluetooth Mate with a Lilypad board. If anyone has any experience with this that they would like to share I would appreciate it!
  • \$\begingroup\$ Was this helpful to you Jennifer? \$\endgroup\$
    – Kellenjb
    Commented Jun 17, 2010 at 2:07
I am having a hard time answering your questions because of a few reasons:
  1. I don't know your history
  2. I don't use a Mac
  3. I have never used the BluetoothMate or Lilypads
With that said, I am going to take a stab to see if I can help.
Bluetooth modules like the BluetoothMate tunnel serial just like FTDI USB chips do. This means that you can write serial on one end and it shows up on the other end just like if you had a serial cable connected to your computer.
With a PC, you would power on the bluetooth module, then from the PC search for the bluetooth module. After connecting, Windows adds a virtual COM port that can be accessed through a terminal such as PuTTY.
On Unix based systems, I believe I remember it being a device such as /dev/ttyUSB0.
Hopefully this helps some.
