I currently am working on a battery powered Atmega328 design, using 4 AA batteries, at around 6.5 volts. I am using it to control a single digital servo, HiTec HS-5645MG. This is done using a RF reciever, here, I know this is not an ideal receiver, but it is my only option currently. I have to have all of these on the single power supply, due to size restraints.
I put them on a solderable "perfboard," and was able to get it to work well, with just a little interference here and there. I used two ceramic decoupling capacitors, 0.1uF and 1uF.
I am working on designing a PCB for this setup, and am quite new to that area altogether, and especially with such a easy to get interference setup like this. I would like to remove the interference I am currently experiencing.
So, my main questions are:
1) Should I take the input voltage directly from the battery's (6.5v) and go to the servo supply? Then the 6.5 will go to the voltage regulator to 5v. Or should I power both with the 5v?
2) Star grounding, or ground plane?
3) For the decoupling capacitors, since the voltage regulators will have two capacitors already, where and what size should the additional decoupling caps go? For the prototype I just used them as close to the input of the chip as possible.
Thank you so much for any/all feedback. Any other suggestions would be much appreciated. There aren't many resources out there for having servo and MCU on the same supply, but I don't have a choice for this project.
EDIT: There will be very little load on the servo, so it should be at the minimum current draw possible for the servo.
