I salvaged the LED disk from a defunct LED light bulb. (The problem was an arced transformer, the LEDs are intact.) It has several unmarked white SMD LEDs soldered on it: 5 lines parallel, with 3 LEDs in series on each line.
I want to use this disk in a strobe. My aim is to get the maximum brightness out of it without damaging the LEDs. Is there any way I can determine (vaguely) its nominal current rating, rather than guessing it?
