I have a device (PC fan) which wants 2.0 amps, and a DC adapter that supplies 1.8 amps; both 12v. As I understand it, using this adapter will cause overheating and reduced voltage.
My probably-foolish theory is that I can cool the adapter (I'm customizing a refrigerator for homebrewing) to make up difference, and prevent either device from failing.
Assuming I keep it safe and dry, what are the effects I should expect from cooling the adapter to ~15ºC? Will the voltage hold at, or move closer to 12? Will either device be damaged?
...is my initial assumption even accurate?
Thanks in advance!
