Firstly, I am not the EE type, but I do have a petty good foundation on physics work on a pretty low level. I was wondering what mechanism it is that measures the magnetic indentation on hard drive platter (if that's even the case), and/or the specifications and variances that determines a 1 or 0.
Like Mark said it's the changes in polarization which is used to encode the data; a magnetic head won't see a static field.
Until some years ago recording was longitudinal, which means the fields were horizontal.
Growing hard disk capacities required a different way: perpendicular recording. The image shows that you can record bits closer together. Currently hard disks have capacities of over 100Gb/in\$^2\$, and it is expected that this technology can achieve 10 times that.
\$\begingroup\$ 100 GB/in2? In only one plate? Amazing! \$\endgroup\$ Commented May 23, 2012 at 7:29
\$\begingroup\$ @clabacchio - well, a 3TB drive will probably use 3 or 4 platters, but that density is for each of them, yes. That's 80nm \$\times\$ 80nm for 1 bit. Amazing indeed. \$\endgroup\$– stevenvhCommented May 23, 2012 at 7:40
\$\begingroup\$ @clabacchio note that it's Gbit/in^2, not GB/in^2, though! \$\endgroup\$– exscapeCommented May 23, 2012 at 10:13
\$\begingroup\$ @exscape still remarkably :) \$\endgroup\$ Commented May 23, 2012 at 10:54
Not an expert on hard drives but its not really an "indentation" unless that has a different meaning in physics.
The "disk" contains a huge number of magnetized regions (really its a ferrous thin film on the disk), when writing to the disk the polarization of these regions is changed by the write head. The actual data, the ones and zeros, is encoded into a series of transitions from one polarization to another. One polarized region isn't really 1 bit, rather the timing of transitions from one polarization to another is what determines if a one or a zero is "read". See http://en.wikipedia.org/wiki/Run-length_limited for a standard coding method.
The read/write heads themselves are really just magnetic coils that can either detect the polarization of the field generated by the disk (read), or induce a polarization on the disk (write).
\$\begingroup\$ The polarization is what I was reffering to as indentations. Basically the induction of the field read by the head. \$\endgroup\$ Commented May 22, 2012 at 21:26
1\$\begingroup\$ Gotcha, I think what your looking to understand is then the encoding part. In many signaling schemes you don't want long strings of zero's or one's as without a transition it becomes difficult to maintain timings. RLE type encoding schemes attempt to guarantee a certain frequency of transitions in the physical medium regardless of the actual data. A similar method is used to avoid biasing the differential lines in ethernet (and for timing). \$\endgroup\$– MarkCommented May 22, 2012 at 21:32
\$\begingroup\$ I should add that this type of encoding is generally used when the "clock" and the "data" are combined into a one signal. This is done most often in signals that need to travel a distance through an unknown environment. Ethernet, and digital audio via S/PDIF are examples, hard drives are another although the reasoning for doing this in a hard drive is mostly that there is no clock, you could i guess encode a clock track next to every data track but you would lose space and since every track on the disk has a different circumference, thus clock, you can't have just 1 master clock. \$\endgroup\$– MarkCommented May 22, 2012 at 21:50
\$\begingroup\$ So this would be kinda sorta like Manchester encoding? \$\endgroup\$– ajs410Commented May 24, 2012 at 17:36
The storage of information on disk is somewhat similar to the representation of information in a barcode. Each location on a disk track is polarized in one of two ways, equivalent to the white and black areas of a barcode; as with a barcode, these polarized regions have various widths which are used to code data. The actual encoding is different, however, since barcodes are generally used to hold either decimal digits or characters chosen from a relatively small set (43 characters in the case of code 39), whereas disk drives are used to store base-256 bytes. Note that older drive technologies used to use just three widths of magnetic-pulse regions, the widest of which was three times the width of the narrowest. Newer drive technologies use many more widths, since the width of the narrowest region the media can support is considerably wider than the minimum discernible distance between widths. In the 1980's, increasing the number of different widths on a drive with a given minimum width would increase usable capacity by 50%. I don't know what the ratio is today.
Information on a randomly-writable disk is divided into sectors, each of which is preceded by a sector header; the sector header is itself preceded and followed by a gap. Both the sector header and the sector begin with special patterns of region widths which cannot occur anywhere else. To read a sector, a drive watches for the special pattern that indicates "sector header", then reads the bytes that follow it. If they match the sector the drive wants, it then watches for a pattern indicating "data header" and reads the associated data. If the data does not match the sector of interest, the drive goes back to looking for another "sector header".
Writing a sector is a little trickier. Drive electronics take a short but non-zero (and not entirely predictable) amount of time to switch between reading and writing mode. To deal with this, drives only write data a whole sector at a time. To write a sector, the drive starts in read mode, waits until it sees the header of the sector to be written; then it switches to write mode, outputs the data, and then switches back to read mode. Because there are gaps before and after the data area, it won't matter if the drive sometimes switches to write mode a little faster or slower, provided that (1) the "start" pattern for a block is preceded by some data that doesn't match the start pattern, so that even if the drive starts "late", the portion of the old block that isn't erased won't match the start pattern (2) the drive must start early enough that it finishes before the start of the next sector.
When reading data, one determines what data is represented by a particular spot on the disk by "counting" the magnetic regions seen since the previous start-of-block marking. When writing data, what data is represented by the spot on the disk the head is passing will be determined by the controller's count of the amount of data written so far. Note that there is no way of predicting precisely which bit will be represented by any spot on the disk before it is written, since there is a certain amount of "slop" in the writing process.
