I have seen too many tutorials on how to increase HC-06 bluetooth module range. They all involve cutting the on-board antenna and adding an external one (a piece of wire or a 2.4GHz antenna). I was wondering how this affects the bleutooth module, for example, the power consumption, the frequency. And the relation between the length of the wire and the transmission range. Can anybody help?
Thanks in advance,
  • \$\begingroup\$ Unfortunately this cannot be answered in a single post. RF design is a complex topic. Maybe start with the question in your title, and use that to lead into the next most interesting question. \$\endgroup\$ Jan 28, 2018 at 11:09
  • \$\begingroup\$ Range, range range...everyone wants more coverage. Bluetooth is designed for short range. If you want more, use different technology, rather than trying to pretty-up a pig with lipstick. \$\endgroup\$
    – glen_geek
    Jan 28, 2018 at 16:49
Looking at an HC-06 module:
what seems "odd" to me is the shape of the antenna. For 2.5 GHz I do not expect that a meandering shape like this (the gold colored part) is any good. My guess is that it is "designed" by someone who doesn't have a clue about antennas at 2.5 GHz.
Other 2.5 GHz antennas are often F-shaped or T-shaped. I saw another meander shape:
but note how is has two connection points, part of it is F-shaped.
My conclusion is that not much thought was put into the HC-06 module's antenna and that probably makes it a very poor antenna. So there's a lot of room for improvement, anything even remotely better will improve performance.
Power consumption wise you would not notice the difference. The actual RF power is quite low and insignificant compared to what the rest of the circuit (modem etc.) uses. Also with a bad antenna most of the RF power reflects back into the chip and is lost. A good antenna will radiate that RF power making things more efficient.
Generally spoken, replacing an antenna changes antenna characteristics. The efficiency of the antenna which is on board can only be improved if it is a bad design. This might be if, e.g. the antenna design was subject restrictions like space on the PCB or price of the PCB-base material inflicting a bad \$\epsilon_r\$ or somthing.
Antenna characteristics can be changed concerning directivity. This can increase range in certain directions but at the cost of range in other directions.
If the matching of the antenna is modified, power consumption can be increased as well as decreased. Normally the built in antenna should be matched quite good, so the radiated power will probably decrease, when you change it. There might be increased losses, but it's also possible that the overall power consumption decreases.
It is not easy to predict the changes in behaviour. Because changing the directional characteristics can increase EIRP and sensitivity very strongly. 12 dB or more is possible at the cost written above.
Length of wire inflicts the matching most. But there is no linear connection between length and transmission lines, because antennas only want to resonate at multiple frequencies of their base frequencies (simply spoken) which is connected to the length of the antenna.
An antenna does not directly influence power consumption. It is simply a passive resonating piece of wire that is "open-ended", hence current cannot flow through it. The power used for transmitting over an antenna therefor depends solely on the circuit trying to send, e.g. the transmit power.
In practice though, wireless circuits are trying to be smart, and they assume that if they sense a weak signal, it is weak not because the antenna is wrong or detuned, but because the wireless peer is far away or blocked. Thus senders often increase their transmit power if the signal is weak in the hope that this way they'll be able to bridge the distance (or get better throughput). So it can be said that a good antenna can reduce power consumption in comparison with a bad one, but this depends entirely on the circuit behind it.
Antenna design is complex, and in general nobody will be able to give a formula to describe signal-to-noise ratio or frequency based on antenna parameters. This is only possible in the simplest cases, and in all others, experts use simulation software to just estimate expected antenna performance. There are some very generic constraints (rule-of-thumbs) though, for example the lower the frequency gets, the larger the antenna you'll need, and other minimum lengths and gaps to be observed (for example those relating to the lambda/4 rule). But the performance of the antenna depends on many other things than just its own geometry, like for example distances to other objects in the vicinity, the materials of those, the geometric form, and even how you get the signal to the antenna (a wrongly matched impedance will loose most of your signal before it even gets to the antenna). Even how the same antenna is oriented in space makes a difference (polarization).
    \$\begingroup\$ Of course current flows through an antenna - how would it radiate power otherwise? \$\endgroup\$
    Jan 28, 2018 at 11:50
  • \$\begingroup\$ @Andyaka: They radiate electromagnetic waves in the frequencies they resonate in the most. Look at these pictures As you can see, an antenna (well, most of them at least) only have a single electric connection. So there is no chance that they close an electronic loop, and so current cannot flow. \$\endgroup\$
    – ultimA
    Jan 28, 2018 at 12:09
  • \$\begingroup\$ You are being extemely ignorant now go and read up on antennas. \$\endgroup\$
    Jan 28, 2018 at 12:14
  • \$\begingroup\$ @Andyaka: I don't think so. Of course there is current movement, but it is not current flow. It is AC, which is what makes it possible to radiate electromagnetic waves. You radiate energy which ofc will equate to power losses, but the radiated power is much less than the input power to the antenna (which is essentially your transmitter's transmit power). In embedded uses, you'll be glad if can get your antenna to radiate more than 1/10 of your input power. Most bluettoth devices have a transmit power in the range of 2-3mW. So the power consumed by the antenna is close to insignificant. \$\endgroup\$
    – ultimA
    Jan 28, 2018 at 12:31
  • \$\begingroup\$ And the consumption I wrote above is only if you send continuously, which with BT you never do. So factoring in the sporadic nature of the communication, the power consumption in the antenna really does not matter. What dominates consumption in the case of TX/RX events is the circuitry involved in the transmitter while active. \$\endgroup\$
    – ultimA
    Jan 28, 2018 at 12:34
