I'm on a quest to build a small cylinder (1/2" diameter) that illuminates for extended periods of time on a single charge. I've looked at numerous small sized batteries and decided on using 2 LR44s rated at ~170 mAh @ 1.5 V (each). This would be my first true engineering project so excuse my shoddy calculations.
I'm debating between using an LED OR an EL Wire design. From what I've read, an LED DC takes ~20 mA for ~7000 mCd luminosity (and ~10 mA for ~3500 using linear relation) which would give me about 34 hours (170 * 2 / 10) of continuous use.
Now from what I've read about EL Wire,
each meter of high brightness EL draws about 10-15 mA at the high voltage
So if I have a 1" length keychain It would draw ~ 0.3 mA (0.025m * 12 mA) which would give me a runtime of ~1,133 hours (170 * 2 / 0.3). Is that at all accurate?
If it is, does an inverter of that size (1/2"x1/2") exist?
