We built a home in a country where electricity is a rare ressource. In order to have energy available all day we bought a bunch of solar panels and several 12 volt batteries. We then used a 8000 watt inverter to power the house.
We are concerned about battery life so we thought about adding an automatic shut off to disconnect the load when the battery discharge to a critical level.
At first we wanted to add a contactor or a relay with a voltage meter to trigger the relay and disconnect the load. The problem is finding a relay that can handle a 8000 watt load on a 12 volt circuit is quite hard.
The other solutions is to use the inverter built in switch to cut off the load. The inverter came with a module that you plug in to remotly power off and power on the inverter. It would be pretty easy to hook it up to a small relay.
I have been looking online for a solution but most module I found only handles a maximum of 100 amp load, since the inverter is capable of 8000 watt I don't think 100 amp would be enough, maybe I'm wrong?
We do not want to spend over 300$ and the module cannot be too heavy since we are limited with transport.
I'm reaching out to the community for a solution.
Edit: I think the safest and easiest solution is to use a volt meter that triggers the inverter low voltage switch, using a relay of some sort, when the batteries voltage is too low. Since the load exceeds 100 amp the load should not go through the volt meter. Maybe by using a shunt, if necessary.
Does anyone know a module that can do that?
