Can a current transformer be damaged with an open secondary coil even if it is powered with an extremely low current?
e.g a small spark gap is made, though no plasma stream is created due to the small current the coil is fed. This results in an open secondary, but will it damage the coil?
... it is unclear if you mean that the resistance of the secondary winding measures infinity \$\endgroup\$
