A force transducer together with its amplifier designed for a full scale load such that it has -5V to +5V range as output. But it is only used with loads outputting -200mV to +200mV. A data acquisition ADC is sampling the output voltages.
The ADC input range is -10 to +10V and its resolution is 16 bit.
Are there any benefits to amplify the transducer output in this case? Could you give me a practical example.
(I guess SNR will not improve because noise will be amplified as well)
