This is my mosfet datasheet RFP30N06LE
i have my schematic setup exactly like this (except powering a 12v load not 60v) and even confirming with a multimeter when i set my gpio pin to high that there is a 3.3v voltage between gate and source. upon disconnecting the gpio out jumper wire and supplying 5v from the raspi instead, current is allowed to flow between drain and source and my load (12v dc fan 500ma) is turned on.
why does this work with the 5v pin and not the 3.3v gpio pins?
I have tried to switch out mosfets in the event there is a bad one i have and even moved them around my breadboard and swapped cables in case of any faulty wiring. Based off the data sheet i see 250uA as the VGS(TH) testing and a max of 2v.
the raspi delivers 3.3v and i think max around 50mA on the 3.3v rail, am i reading these mosfet charts incorrect?
