I'm not from an electrical background and am looking for possible options to amplify the load cell output. I'm using a load cell with a 2 mV/V output.
http://www.sentranllc.com/pub/datasheets/20180327140123_DSPA00101_180326.pdf
The acquisition system in my test setup is only sensitive to a 0-5V range. Please share any thoughts on possible ways to amplify the signal.
Thank you in advance!
  • \$\begingroup\$ What bandwidth? What accuracy? What drift toleration? What form of excitation will you use? What power supplies will you use? What output clamping methods need to be incorporated? What offset adjustment processes are you considering? Are you considering variable gain amplification? \$\endgroup\$
    Commented Jun 11, 2019 at 16:31
Generally you would use some form of regulated excitation and a signal conditioning circuit with trim for bias and gain and and some reasonable frequency response for the intended application.
Since the input signal is differential, an instrumentation amplifier is typically used.
Since the input signal is relatively low level, often a "zero drift" or "chopper stabilized" type is specified. The load cell itself has drift both with temperature and with creep. Applications like scales where the scale is zero'd prior to measurement and then the load is applied for a short time can get away with less precise circuits as far as bias drift goes.
For consumer applications, a part such as the Avia Semiconductor (Xiamen, China) HX711 is sometimes used, which includes excitation, analog front end with PGA (programmable gain amplifier) and high resolution ADC converter.
You are looking for an "instrumentation amplifier". It's a very broad topic so you will need to use the details of your application to narrow the choices.
