I want to use a 4p4c modular jack for carrying isoSPI data and 12V at <1.5A and am not sure if the connector or cable could handle that
1 Answer
I thought you were way off with 1.5 A but a browse through Farnell's list of RJ22 connectors found this.
Figure 1. Extract from MTP-44U - CAT5 RJ22 MODULAR PLUG, 4 POSITION, 1 PORT.
The voltage isn't a problem as they have to take telephone ringing voltage which is about 100 V AC. I was surprised at the 1.5 A current rating but be aware that the you'll have to have the same rating on the socket and your conductors will be rather small for that current too.
