I'm trying to reverse engineer this system to try to read an adressable transducer. In this amp op configuration I don't know what this yellow component is supposed to do.
marked component
The component label is: 605 16 k 601
label
Any information or idea would much apreciated.
It's a capacitor, the "K" on the second row identifies it as from Kemet.
Marking is value in pF, so 6800,000 = 6.8uF, voltage is 16V per the second row.
Third row is a manufactured date code.
Possible series - there's a few it could be -
https://content.kemet.com/datasheets/KEM_T2008_T494.pdf
Its a tantalum capacitor probably 6.8uF, it appears that this cap is used as a filter to keep the voltage stable on the + terminal of the LM324
