I'm given a AC to DC power supply with only the inputs and output specified. It was probably made after 2000, and the ENERGY STAR program mandate to add PFC correction to power supplies may or may not have been implemented.
Some of these are AC power bricks (e.g. laptops), others are PC case supplies.
We've a bench to set the supply on which has multimeters, an oscilloscope, plus parts (resistors, caps, chokes) to rig up some loads for the supply.
What can I do on the bench to determine if the supply probably does/does not add back a PFC?
I need to avoid hooking a newer PFC supply to an older/cheaper non-sine wave UPS (Uninterruptible Power Supply). A stepped wave form from a UPS on battery can blow the PFC supplies.
