I am trying to figure out how to calculate the sensitivity of a circuit, especially the sensitivity of a damping ratio (how much the damping ratio changes as each component value varies).
Expression for zeta is quite long and complicated, so I prefer not to take partial derivative. I would like to do something like:
calculate the value of zeta when R = 100 ohms.
calculate the value of zeta when R = 101 ohms.
then divide the change in zeta by the change in R.
In this case, how would I normalize this sensitivity value (x/y part)?
  • \$\begingroup\$ In this case your "y" is zeta and your "x" is R. So just subsitute the values in. \$\endgroup\$
    – The Photon
    Commented Oct 2, 2019 at 15:56
$$S_R^\zeta \approx \frac{R}{\zeta}\frac{\Delta \zeta}{\Delta R}$$
  • \$\begingroup\$ Would I have to substitute original values or R and zeta for normalizing? \$\endgroup\$
    – user207787
    Commented Oct 2, 2019 at 15:58
  • \$\begingroup\$ @user207787, what do you mean by "original" values? You only have two "experimental" values: \$\zeta(R=100)\$ and \$\zeta(R=101)\$. Use those to calculate \$\Delta \zeta\$. \$\endgroup\$
    – The Photon
    Commented Oct 2, 2019 at 16:00
  • \$\begingroup\$ Sorry, I meant "Would I have to substitute original values *for R and zeta for normalizing?". For R/zeta, do I have to plug in 100 or 101? \$\endgroup\$
    – user207787
    Commented Oct 2, 2019 at 16:11
  • \$\begingroup\$ @user207787, if it makes a difference, you should use a smaller difference between your two R values, like 99.9 and 100.1 or something. \$\endgroup\$
    – The Photon
    Commented Oct 2, 2019 at 16:12
