I am trying to setup the timer update interrupt of a stm32f103cb. My setup and interrupt code looks as following:
void TIM2_IRQHandler(void)
    GPIOB->BSRR = 1UL << 1; // turn on led, works if function is called manually
    TIM2->SR = ~1;
void setup(void)
    RCC->APB1ENR |= 1; // enable clock for TIM2
    TIM2->PSC = 71;
    TIM2->ARR = 0xFFFF;
    NVIC->ISER[0] |= TIM2_IRQn; //TIM2_IRQn == 28
    NVIC->IP[7] |= 2 << 4;
    TIM2->SR = 0;
    TIM2->CNT = 0;
    TIM2->DIER = 1; // enable update interrupt
    TIM2->CR1 = 1; // enable timer
From my understanding TIM2_IRQHandler should be called, everytime the timer updates, but that does not happen. Some things i know:
  • The rest of the programm runs fine, the interrupt is just never triggered
  • The timer is running
  • The update interrupt flag in TIM2->SR is getting set correctly, everytime the timer updates
Am i forgetting something in the setup or is the error somewhere else ?
  • \$\begingroup\$ Is the timer working at all? Can you poll it and see if the value is changing? \$\endgroup\$ Commented Oct 14, 2019 at 20:31
    \$\begingroup\$ I polled the timer and the value is changing \$\endgroup\$ Commented Oct 14, 2019 at 20:37
  • \$\begingroup\$ Is there something like a global interrupt enable? \$\endgroup\$
    – rdtsc
    Commented Oct 14, 2019 at 20:58
  • \$\begingroup\$ Always clear the interrupt flag (i.e. set the SR) as early as possible in the ISR, or the interrupt might be triggered again endlessly. \$\endgroup\$
    – Erlkoenig
    Commented Oct 15, 2019 at 4:55
I figured it out.
should be
NVIC->ISER[0] = 1UL << TIM2_IRQn;
because to enable the interrupt you want to set bit 28, not write 28 as bit value to the register. Now it works as expected.
  • \$\begingroup\$ It should be NVIC->ISER[TIM2_IRQn/32], in case the interrupt number is larger than 31. \$\endgroup\$
    – Erlkoenig
    Commented Oct 15, 2019 at 4:38
  • \$\begingroup\$ Please mark your own answer so that it is shown as "accepted" in the lists. @Erlkoenig It has to be TIM2_IRQn % 32. Since I don't use that controller I don't know, but the header file might already define the correct value even for interrupts in ISER1 and ISER2. \$\endgroup\$ Commented Oct 15, 2019 at 6:37
  • \$\begingroup\$ @thebusybee No, the % 32 would have to go on the right side: NVIC->ISER[TIM2_IRQn/32] = (1 << (TIM2_IRQn%32));. This is is what ARM does, but using bitwise operations instead of arithmetic to make it less readable. This is an example in assembly doing the same thing. \$\endgroup\$
    – Erlkoenig
    Commented Oct 15, 2019 at 6:59
  • \$\begingroup\$ @Erlkoenig Right, I wrote my comment too fast. Thanks for clarifying! \$\endgroup\$ Commented Oct 15, 2019 at 7:41
