I need help using a 10 kΩ fixed resistor. I connected the red and black wire but I'm not sure what to do with the white wire. I know that this is for the thermistor. The battery will not charge if the white wire is not connected.
I know that I need to use a resistor but I dont know where exactly to connect it. If you can show a picture on how the wires should be connected, it would be very helpful. P My battery is a 3.7 V Li-po battery by the way.
I found a similar question and I believe what the person did to resolve the issue is what I need to do. However, I have no idea on how to add the resistor.
